Labview writing incorrect DIO port in USB 8451
There are 8 ports on the 8451 p0.0 to p0.7. I'm trying to control multiple relays, hence I'm using multiple ports. If i use multiple lines in one port, then I'll have to code for all the bits in a line every time I have to send a signal to only one relay, which might make stuff complicated.
Message 11 of 18
(1,887 Views)
Accepted by topic author vedsoni1996
Wrong!  That is 1 port (P0) with 8 lines (0 - 7).
Wrong again.  You use the Write Digital Line like I showed in my previous post.
It sounds like what you really want is something like the USB-6509, which has 12 digital ports (P0 to P11), 8 lines per port, adding up to 96 individual lines.  And,yes, you can create a separate task at the line or the port level.  So control of your individual relays would still be simple.
Message 12 of 18
(1,881 Views)
Okay.. Thanks a lot! I'll code using the write line command.
Message 13 of 18
(1,871 Views)
Hey, did you managed to make it work?
Having same problem.
If you did, could you please send VI?
Message 14 of 18
(1,726 Views)
Hey!
I cannot send you the VI, but here's a picture of the same:
Basically, there's only 1 port with 8 lines (0 - 7) on the NI 8451, so keep the port number unconnected and set the line number to what you want.
Message 15 of 18
(1,712 Views)
For some reason i can read values but cannot write.
Tried whole day. Not working (
Even simple LED connection not working.
Message 16 of 18
(1,708 Views)
Refer to the image in my previous post. For writing values, you need to set the Logic Value control to FALSE, I guess. Try changing it from 0/1 and see what happens. Best thing is to refer to NI 8451 user manual.
Message 17 of 18
(1,701 Views)
Just saw your image. Why have you put the writing part inside an infinite while loop?
Your while loop will never stop if you've set FALSE as a stopping condition. I'd say remove the while loop.
And as I said before, try changing the value of the boolean. Also, these are the properties I set in my NI-845x device configuration:
Try using these.
Message 18 of 18
(1,699 Views)
