Labview to Raspberry Pi
I am trying to interface a Keithley DAQ6510 LabView code with Raspberry Pi. I want to send a signal that is acquired from my data acquisition unit to Raspberry Pi. Basically I want to send a string from a for loop to a while loop. My code is attached and if you look at the block diagram you will see where my issue is. Does anyone know how to do this?
(1,970 Views)
Hi, @HALOBEAST999,
Just to make sure I understand, regarding sending the data from your for loop to your while loop.
  1. Are you trying to send the data every iteration of the for loop?
  2. Or build a packet of data in the for-loop that is then sent to the while loop?
For the first, you'll need some other way of transferring the data (a Producer-Consumer design with a queue looks appropriate to my inexperienced eye).
For the second, if you want to:
  • Send one aggregated string, then you'll need to
    • build it up in the for loop (or else combine it outside of the for loop)
  • Send each element from the Auto-indexed array
    • Make the while loop input tunnel as "Auto-Indexed"
    • (Something tells me this has some big red flags with it, but I think someone more experienced should comment.)
Which of these (or something else) are you trying to do?
-joeorbob
(1,947 Views)
