Labview "Tab" under string function
The file format you have described, where rows are separated by New Lines, and columns are separated by a delimiter (typically a <Tab> or a <comma>(,)) is called a "Delimited" file, or (if the separator is a comma), a Comma-Separated Variables (.csv) File.  Note that if you have Microsoft Excel installed, it will give .csv files an "Excel-like" icon, causing LabVIEW users to erroneously call this an "Excel" file.
As other responders have noted, LabVIEW provides a function to read and write Delimited files.  In LabVIEW 2014 and earlier, this was called Read from (or Write to) Spreadsheet File, while in LabVIEW 2015 and later, it goes by the name Read (or Write) Delimited Spreadsheet.  By default, these files use a <tab> delimiter.  There are also two functions in the String Palette that convert "Spreadsheet strings" (rows separated by New Lines, columns separated by Delimiter) into Arrays, and vice versa.
Message 11 of 19
(2,097 Views)
Thanks for the assistance 🙂
However the "read delimited spreadsheet" only works for double function? I wish to have sring functions and the string to be also shown out as uploaded....
Message 12 of 19
(2,059 Views)
Read Delimited spreadsheet will work fine for Double,Integer and String?
What do you want to achive? why specifically string?
Message 13 of 19
(2,052 Views)
Try this
Message 14 of 19
(2,047 Views)
Hey Palanivel,
Thanks again for the help, I maanged to recostruct your vi and mine by linking the file path dialog together to form as set.
It works perfectly(I think lol) and now I have the following issues.
1)I have to plot out the histogram of the 3 XY Graphs you have helped me with.
2)I have to collect the exact data out and fill it up to the tank to show the actual amount for C, G and D
3)On the left side I have to log the various data as mentioned, namely the previous test I have conducted, number of test to conduct and the renaming port.
Message 15 of 19
(2,044 Views)
What is mean by exact data?, from where you will collect exact data?
Explore more about how to save text file for logging data.
Message 16 of 19
(2,035 Views)
2) From the text file data obtained, so for example the data shows the 3 columns which is C,G and D values. the values have to be filled up to the tank.
3) For this case I feel that 2) should be of pirority instead. Before I rush to 3)
Message 17 of 19
(2,032 Views)
The Slider/tank expects Scalar value but the data from file is an array, how do you map an array as an input to a scalar terminal?
Message 18 of 19
(2,016 Views)
Sorry for the late reply Palanivel,
I think I have to consult my team for this part...
As for 1) as mentioned earlier, should I use the "Build XY-graph" function to link all 3 data to form a "Create Histogram?"
Regards
John
Message 19 of 19
(1,936 Views)
