Labview on Win 10 ARM 64 on Raspberry PI
@rolfk wrote:
You are all barking up the wrong tree here.
I figured that much.
I also expected you'd know the details.
Message 21 of 24
(1,565 Views)
A few years ago I experimented with Windows 10 on ARM and LabVIEW.  Here was my conclusion which basically is that only LabVIEW 2016 could be used due to SSE optimizations, and that the runtime engine needed to be manually installed.  I was able to get code running, and publishing LabVIEW VI front panels to web pages using WebSockets.
https://forums.ni.com/t5/LabVIEW/Labview-for-raspberry-pi-3/m-p/4031067#M1155884
At the time several limitations existed with the Windows 10 on Pi configuration, which I think have been improved since then.
Message 22 of 24
(1,543 Views)
Any chance MS will pick this up?
LabVIEW can't be the only application with this problem.
Message 23 of 24
(1,524 Views)
Hola, pudiste correr los ejecutables de labview en la PI?
Message 24 of 24
(1,455 Views)
