Labview not detecting NI-VISA com port even though X-sens sensor is connected
The sensor I connected to the computer appears in the "Sensors" group in "Device manager", but the port is not visible. Therefore, the NI-VISA com port is not detected. Is there any other way to communicate with the device in serial?
Any opinion given is worthy of respect.
Message 1 of 11
(3,733 Views)
I don't know exactly what sensor you are using that shows up in Windows Device manager Sensors group, so I am just guessing here...
In general NI-MAX will only recognize and identify instruments that are made by NI, use one of the common industry standards (IEE 488.2, VX-11. etc.), or know how to inform NI-MAX of their presence.
That being said, I had a similar (maybe) problem with an instrument here and it came down to how the instrument drivers were installed.
So if you can install it so it shows up in the Windows Device Manager in the "Test and Measurement Devices" group instead of in the "Sensors" group it might work.
=== Engineer Ambiguously ===
Message 2 of 11
(3,706 Views)
Most XSense sensors, except the MTi-600 which has a CAN port, provide poth an RS-232 port and USB port, and that USB sensor should be seen by Windows as a serial communication port by default.You can't use the RS-232 port if the USB port is connected as those two ports can only be used either/or, and if the sensor detects a connected USB host interface it will switch of the RS-232 port.
However if it was recognized as a serial port it would be visible under Ports (COM & LPT). Only devices which Windows recognizes as serial port will be accessible by NI-VISA & NI-MAX. If your Windows system installs different drivers for some reason (maybe because you have some XSense application installed which uses its own drivers, then NI-MAX can not see that device.
It may be necessary to use the CA-USB2-MTI cable instead of the CA-USB-MTI cable in order to use the XSense sensor as a serial port device that can be accessed from NI-MAX/NI-VISA. The CA-USB2-MTI cable has a little black box that converts the on sensor RS-232 port into a virtual USB-COMM port.
Rolf Kalbermatter  My Blog
Message 3 of 11
(3,699 Views)
Mr. , I tried the CA-USB2-MTI cable you mentioned, but it couldn't connect. I'm using MTi-G-710.
is there an alternative solution?
Message 4 of 11
(3,672 Views)
mr. The method you said sounds good, but how can I do it, I don't understand how to do it exactly?
Can you explain a little more about this, if I plug in the usb, it adds it directly to the Sensors group.
Message 5 of 11
(3,669 Views)
@constructionworker wrote:
Mr. , I tried the CA-USB2-MTI cable you mentioned, but it couldn't connect. I'm using MTi-G-710. is there an alternative solution?
If you use the CA-USB2-MTI cable, do you see in Windows Device Manager an entry for this device under Ports (COM & LPT). As long as your device does not get recognized by Windows as a serial port and properly getting installed as such (no yellow exclamation mark on the item in Device Manager) NI-VISA will not be able to see it.
Test & Measurement devices are a special class of USB devices that have been specifically build to support this type of USB-TMC class. Only some T&M manufacturers like Keysight, Tektronix/Keithley, and similar manufacturers offering oscilloscopes, DMMs, etc. do that. It is fairly safe to assume that your XSens sensor won't. XSens is not a T&M company by a long stretch and would likely not even bother to checkout what the USB-TMC standard contains of.
XSens specifically uses their own Xbus binary protocol, although they also seem to support reporting data in the NMEA format that many GPS systems use. But the NMEA format is a pure talk only protocol, the sensor spits out a new record every so many milliseconds as an ASCII string.
Their documentation about how the built in USB port is used and what type of USB class profile it uses seems non-existent. Maybe there is some information in the SDK that you can download but a >500MB executable that must be installed on a system to just check out some maybe existing documentation is not something I want to do on my working computer.
Message 6 of 11
(3,653 Views)
Mr rolfk,If I use the CA-USB 6-MTI cable, it is detected as Com port, but the connection cannot be established and the information cannot be read. I tested it with X-sens' own program and it cannot connect.
Message 7 of 11
(3,641 Views)
Accepted by constructionworker
Well, your responses are always concise and undetailed. So you use the CA-USB6-MTI with the MTi-G-710 GNSS/INS. I hope your order number for your MTi-G-710 GNSS/INS starts with 0779xxxx, otherwise you clearly try to use the wrong cable.
The MTi-710 can be ordered in 3 interface versions
Interface Variant           RS232+USB        RS422                RS485+USB
Order Number              0778xxxx             0779xxxx            077Bxxxx
necessary cable           CA-USB2-MTI     CA-USB6-MTI     CA-USB4-MTI
In addition the CA-USB-MTI cable can be used with the RS-232 and RS-485 variant to directly connect it to an USB port, but then the device must be accessed through WinUSB (or libusb on Linux and Mac) in an XSens proprietary USB protocol (and you certainly do not want to venture into using VISA USB Raw communication to talk to the device in such a way, believe me).
So assuming you have used the correct cable for your MTi-710 product you first have to make sure that there is indeed a valid COM port in the Windows device manager. As long as Windows doesn't see a COM port for this device, everything else is a moot exercise. And then you can start testing with the XSens provided test software but likely will have to tell it somewhere which COM port to use to communicate with your sensor. The application likely won't try to find devices on the COM port on its own, as that could have some very interrupting effect on other potentially connected serial devices, which might not like at all being send binary XBus protocol messages to test if it is an XSens device.
And if that works you can switch off the XSens application and start trying to connect to the device in NI-MAX. And then go to the XSens website and download their XBus protocol document and start hacking. Binary serial communication can be a daunting task so get your caffeine and your stress relief ball ready. 😀
Message 8 of 11
(3,627 Views)
thank you for your replies mr.rolfk
necessary cable           CA-USB2-MTI   but I have CA-USB6-MTI and CA-USB-MTI
I have the wrong cable. Because of this, I've given up on testing now. Is there a way to use the CA-USB-MTI on windows 10? What do I need to do to use it over WinUSB?
I'm trying to use the sample code shared by X-sens in Labview.
Message 9 of 11
(3,617 Views)
WinUSB is a DLL interface that could theoretically be called with the LabVIEW Call Library Node. Practically that DLL interface is complex enough that you would have to start playing C compiler yourself on the LabVIEW diagram to get it to work at all. So you would first have to learn C programming and well very far beyond the point of being able to write a "Hello World" program. Even for someone like me who knows what it would involve, it is magnitudes more expensive than buying the correct cable.
They do provide LabVIEW VIs???? If so they surely will use NI VISA functions (or maybe their .Net assembly?) If you talk about using their sample C code, well that is not something you can directly use in LabVIEW.
Message 10 of 11
(3,604 Views)
