Labview load error code 3
I've run into the same error today after saving a top level VI in LV2009 (9.0, Professional Development System, 32bits runnning on a 64bits laptop.)  The error was "labview load error code 3".  The trick of modifying the .ini file was NOT working for me either.  I would get the exact same error.
My solution was to open the VI in LV2011 and Save it for LV2009.  I had to resolve a few conflicts but that was overall pretty straightforward.
Message 11 of 23
(3,764 Views)
I was making a VI in one of my machines with Labview 2011, and got the wiring issue. The code is no longer opening in Labview 2011.
I try to update to SP1, gave me license issues.
I open it on Labview 2012 SP1 and got the same error.
Could some one help me out with this VI?
Attached
Message 12 of 23
(3,673 Views)
It did not work for me with Labview 2012.
Could you revise my VI and fix it?
Gaston Tudury, PhD
Message 13 of 23
(3,673 Views)
Hi Gaston,
the same error with LV2019.
Simple solution: get an older (but working) copy from your SCC system. Or from your backup, when you don't use any SCC…
Message 14 of 23
(3,671 Views)
Here you go.  Saved for LV12, missing several subVIs.
Message 15 of 23
(3,666 Views)
What you mean by SCC system? Sorry, unfamiliar with this acronym.
Message 16 of 23
(3,668 Views)
Thank you very much!
Could you let me know what you did to fix it?
Gaston
Message 17 of 23
(3,665 Views)
Hi Gaston,
It's "Source Code Control". SCC is also mentioned in the LabVIEW help and LabVIEW options…
Message 18 of 23
(3,662 Views)
Gaston
Just requires the Fonzie touch....
Spoiler
Spoiler
Actually I just removed the corrupt connector pane chunk from the file,  LV can open the VI without it.
Message 19 of 23
(3,659 Views)
I was not able to open it with Labview 2012 myself...
Someone also answer me that could not open with Labview 2019... (you could see that on my other post for help!).
Message 20 of 23
(3,644 Views)
