Good morning, today trouble I've met is about the installer. I've installed my stand alone application on a target machine with Win XP Pro and Office 2000 SR. The installer stopped with error 1704. I don't know if i've done the right choise because the installer removed the Office package from the machine! Do you know what the problem is (are) and how i can fix it (the application uses excel to generate reports)?
It might be that something went wrong with the installation of your Office Products. As far as the LabVIEW Application Installation is concerned, you want to make sure you are building your application correctly. Follow the information in this online document
