Labview how to connect the database via .dll library
Hi, All
   I faced a trouble, normally the .dll library can connect the database through C# program, but I invoke the .dll library can't
connect this database , I don't know why ,I used the method is the same with C#, please refer photo and .dll file,thanks
lavview connecting fail
C# connect successful
Message 1 of 8
(2,501 Views)
what's the reason? why labview to invoke the sajetconnect.dll file is failed,but C# use the same method is successful ?thanks a lot
Message 2 of 8
(2,499 Views)
can you help to resolve this problem? thanks so much~
Message 3 of 8
(2,444 Views)
Another topic related to SajetConnect.dll - https://forums.ni.com/t5/LabVIEW/call-dll-issue/td-p/1997927
Santhosh
Soliton Technologies
Message 4 of 8
(2,425 Views)
Thanks, it seems not the same issue, their faced problem is not create .ini file, but i faced is can't connect the server invoke dll via labview,thanks
Message 5 of 8
(2,415 Views)
Thanks ,Resolved
Message 6 of 8
(2,407 Views)
Please tell us what you did to resolve this.
Rolf Kalbermatter  My Blog
Message 7 of 8
(2,396 Views)
as you reminder, need to create the .exe file to run and then connected the server,thanks
Message 8 of 8
(2,390 Views)
