Labview graphs and data displayed on them
I am using graphs to display measured values read from an NI ELVIS board. the problem is that the graphs only display data read between 0 and 10 milli seconds . i have tried changing the scale (time axis) from auto to custom by unchecking the auto-scale box and using my own ranges. the scale does get streched but ony data between 0 and 10 milli seconds is displayed on the graph. how do i show data from a period longer than 10ms e.g displaying data from a 10 minute log on the LabView?
(3,230 Views)
Sounds like you should really be using a chart and not a graph. A chart has a settable history and a graph does not unless you write the program to retain older values.
(3,227 Views)
I have tried using charts but the same thing still happens.
what i am actually doing with my program is reading data using the DAQmx from an NI ELVIS board and then store the data as an LVM file using the "Write LabVIEW Measurment File" express vi. I then use the "Read LabVIEW Measurement file" express vi to retrieve the logged data.
Is there another way of getting back the logged data in a graphical format because using the graphs or charts does not seem to be working very well?
(3,203 Views)
Please post your code so we can help you further.  You should be able to do what you want to do.  Thanks!
(3,190 Views)
Hi Chusta,
Please post your code to the forum so that we can troubleshoot it. Thanks!
Ipshita C.
(3,176 Views)
Well.. thanks you very much for your advice about the charts now everything is working just fine. I just had to change a couple of settings on the chart properties.
your help is much apreciated
(3,164 Views)
