Create Express VI
Hello NI,
                   I want to create vi just  like a express vi... i think it could possible with labview itself.. let u say.. how to pop up the configuration window when i drop down the vi  on the block diagram?
Balaji DP
(3,574 Views)
You could get the NI LabVIEW Express VI Development Toolkit.
This functionality is included in LabVIEW 8.6, so upgrading would be another option. 🙂
(3,571 Views)
is it possible to do without using express toolkit?.... it should have some logic....
Balaji DP
(3,568 Views)
Express VIs use a few trick that are probably not exposed to the general programmer.
For example how would you make a running express front panel pop up whenever an express VI icon is dropped on the diagram or double-clicked while in edit mode?
And how would you make it interactively change the underlying data?
(3,531 Views)
