Labview freezes while loading a subvi in edit mode
Do the sub-VI that hang-up contain VISA references?
Ben
Message 11 of 17
(1,248 Views)
I just repaired LabVIEW, and haven't used it a lot yet but it seems to be better now. And to Ben, yes my sub-VIs that hang-up contain VISA references.
Thomas
Message 12 of 17
(1,237 Views)
"...my sub-VIs that hang-up contain VISA references."
Refresh MAX. You may be hanging trying to find a non-existatnt device.
Also make sure you have latest and greatest VISA. There was a bug back then that would cause VISA to hang LV.
Ben
Message 13 of 17
(1,212 Views)
Ben:
Would VISA still hang looking for a non-existant device even tough he said it hangs during edit? I wouldn't expect the default setting of the VISA reference to be queried just by opening the VI for edit, only for a running VI.
tBlum:
Does the VI run okay when you just hit run without opening the subVI?
Message 14 of 17
(1,207 Views)
Matt wrote;
I was just venturing a guess based on the question, "When do the device names get populated?"
Ben
Message Edited by Ben on 05-25-2007 12:49 PM
Message 15 of 17
(1,196 Views)
In short the answer is "oh yeah". Had a lot of trouble with that when I first started loading old code into V8. Opening the front panel of NI Scope VIs and the like took many minutes...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 16 of 17
(1,180 Views)
Well I have the latest VISA version, but the repair I did a few days ago seemed to fix the issue.
Thanks guys for your help, and I hope I won't have this problem again.
Cheers,
Thomas
Message 17 of 17
(1,123 Views)
