Labview file missing or currupt
I have created a labview program that creates and labels an .xls spreadsheet.  However, while the program was closing it asked me to save changes to the report generation vi's  (stupid and asks every time) I mistakenly picked yes and then my computer shut off (Bill Gates issue not yours.)  In any case now when I try to run that vi it states that the report generation (packaged not mine)  vi's are corrupt.  I tried restoring my computer to pre labview and reinstalling but I still have the same problem on this computer.  On my other labview machine it works fine any suggestions?  The code is attached.
Chris
(2,679 Views)
Hi Chris,
I'm not sure what you're trying to do by opening the File with Open/Create/Replace at the same time you're writing the file with Save Report to File.  Would you please explain what you want to do here?  I recommend you take this part of your code out for now.  What version of LabVIEW and the toolkit are you using?  The first thing to try would be a Repair of the RGT in Add/Remove Programs.
(2,633 Views)
