Labview executable suddenly started to Self-restart testing
this program has been working fine for over a year, now it is self-restarting a test.  the test is called with an F12 key and should finish and then be ready to accept other commands but is now repeating the same test as if a button was stuck down.  Has any body experienced this before?
Jim
(3,759 Views)
Could the F12 key be physically stuck?
(3,748 Views)
Good Question!  When I launch the program and it finishes initializing, you have several options to select.  if the key were stuck down then I think it would start testing as soon as it was polled, but it doesn't.  when I sellect the key it then performs the test, finishes and returns to the polling mode waiting for a command.  within about a half second it starts again.  If I am quick I can press the 'Exit' button to exit the program totally, but that isn't what I want to happen.
I ran the source code version of the program and it does not have this problem.
Thanks for trying...
regards
Jim
(3,744 Views)
Jim,
Have you tried re-creating the executable from the source code?
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(3,722 Views)
Abhinav T.
I have not tried to re-do the source to executable.  I did consider that and my thought was that if the executable has changed, I would expect a more serious condition.  However I will try that as I am still at a loss to explain the problem.  I'll let you know.
Regards
Jim
(3,700 Views)
Abhinav,
I went to the Test Station in question to re-make the executable this morning.  I first ran the executable to verify the problem still existed.  I does not repeat the test anymore!  The system has been shut down over the weekend, which possibly explains this.  Last week when this first occurred, I performed a computer cold restart twice, which did not clear the problem then.  I am now letting it run for the rest of the day to see if will fail again.  There shouldn't be a temperature factor here but there is always a chance.  I will update you later on the results.  I hope this is not a 'haunting'.
Regards
Jim
(3,685 Views)
Abhinav,
Well, 20 hours later and it still is working perfect.  It appears this system was temporarily haunted.  Thanks to all for your input.
Regards
Jim A.
(3,668 Views)
