Hi flai,
I've installed (unzipped the instrument driver file to the instr.lib folder) and uninstalled (deleted the tkafg3k folder in the instr.lib folder) the tkafg3k driver on LabVIEW 8.5.1 without any trouble. I did both of these without LabVIEW running.
When you installed and removed the instrument driver, did you do it like myself by just adding and removing the zipped files from the instr.lib folder? Does LabVIEW crash upon startup, when you try to use a program that calls VIs from the instrument driver, or when you're not doing anything in particular?
Kevin S.
Applications Engineer
