Labview crashes when building exe
Hi all,
I have created a Project and have a main vi which works fine in the development environment. When I try to build exe for the same, LabVIEW crashes. I dont get it why. If anyone could help on this, you are welcome.
LabVIEW version:2013, 64 bit
Prabhu
(5,071 Views)
Hi Prabhu,
either provide full error descriptions - or your complete project so somebody else can try to build your EXE…
(5,058 Views)
Can you share the image of your project i.e. all the componenet which is being added to project? The way you are doing also matters
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(5,048 Views)
Accepted by Prabhu16
Thanks Ranjeet. I got that to work, by marking remove unused files from project libraries. I think the problem was about memory.
Prabhu
(5,040 Views)
GREAT !!!!
Then mark your reply as answer..This might be useful to someone in future
--Ranjeet
(5,023 Views)
Labview kept crashing when I tried to build a PPL from an Actor Framework project in LV2018. The problem was fixed for me by doing the opposite, I unchecked "Remove Unused members of project libraries".
If building a PPL I would also recommend dragging any external lvlib files into the lvlib that you want to create the PPL from and then back out again, then do a mass compile of the project (Tools > Advanced > Mass Compile). This uncovered many broken VIs and unused VIs that needed to disconnected from libraries. Now my PPL finally builds after trying to debug this for weeks
(3,840 Views)
