Labview command-line interface
calling .vi file through command prompt is working using the command
C:\Program Files\National Instruments\LabVIEW 7.1\LabVIEW.exe "C:\test.vi" –– 4 5
and the .vi file which is configured for addition operation is taking inputs and printing the output in front panel as 9.
Now how can i get this output(9) to be printed in command prompt
Message 11 of 14
(1,911 Views)
You can't, or at least, not easily. LabVIEW has no functions for writing to StdOut or StdErr so I think you have to use DLL calls into Windows or .NET to find the process/command-line instance and then call the appropriate functions to output to the console.
There are some posts about it here:
http://forums.ni.com/t5/LabVIEW/how-to-make-a-VI-write-to-standard-output/td-p/347392
https://lavag.org/topic/13486-printing-to-the-standard-output/
(blog)
Message 12 of 14
(1,908 Views)
hi
how a .lib file can be created in labview15.0 version
Message 13 of 14
(1,850 Views)
@PrathyushaAjjugal wrote:
hi
Do you mean a .LLB file? LLBs are not really recommended any more (use .lvlib instead), but you can still create LLBs by going to Tools -> LLB Manager...
(blog)
Message 14 of 14
(1,837 Views)
