Labview and systemrequirements
Hi! Can I run a labview-application( .exe) file on intel 486 and VGA-Monitor?
Thanks!
(2,826 Views)
Well, I used to... depends on the application and what version of LabVIEW you're using. VGA isn't a problem, but LV 6 might not run so well on a low memory, low speed processor. Of course, you might consider installing Linux and using LV for Linux instead. That would make the prospect much more likely than if you install Win2K or XP on a 486 system.
(2,826 Views)
You can. I've still got of couple of old 486 pc's running Win95 and a LabVIEW 6.1 exe. If you can add memory to the computer, you'll be better off.
(2,826 Views)
