DAQ using one PC but two carts simultaneously
How can I do a DAQ, using one computer but two different carts, in the same time? is there any example about?
(2,749 Views)
Do you mean two different cards? Because NI-DAQ (theoretically) makes that pretty much transparent. Of course, it gets more difficult if you're talking about true simultaneity in sampling.
If you do mean carts, it'd be easier to answer if you told us what was on your carts 🙂
(2,749 Views)
Greetings,
It is quite simple to use two different DAQ cards in the same computer at the same time. The key to the task is synchronizing the two devices. This is accomplished using the RTSI bus. Below is the link to a tutorial which discusses Advanced Synchronization Techniques for Data Acquisition:
http://zone.ni.com/devzone/conceptd.nsf/2d17d611efb58b22862567a9006ffe76/ced34fe76e435edb8625686b006d9b56?OpenDocument
Examples are definitely available to demonstrate the use of multiple devices simultaneously. If the two DAQ cards are E-Series, the examples are shipped with LabVIEW and located in Hardware Input and Output >> DAQ >> Multiple Devices. This path refers to LabVIEW 6.1, but these examples are also available in previous versions under differe
nt paths. Examples for other DAQ cards are available on NI's Web Site at the following location:
http://www.ni.com/devzone/dev_exchange/ex_search.htm
Good luck with your application.
Spencer S.
(2,749 Views)
