Labview and profibus
Is it possible to use labview with a profibus card in the computer?
I have a Hilscher card that I would like to use with labview, but I have no
idea how to make it work.
/david
(9,101 Views)
The easiest is to use NI cards, then you get LabVIEW drivers...however we have used Hilscher too - but then we had to write a wrapper around their Cif32dll.dll.
Attached is a file containing VIs to open, close, read and write to the Hilscher profibus cards using that dll. I have not included the dll, you will need to put that dll together with the VIs.
The VIs are not a general library, it's something made by a collegue of mine for internal use to solve a specific task, however unless someone has made a general solution at least this will give you an idea of how to move forward...
Mads
(9,100 Views)
David,
More than likely the Profibus card software included an OPC server that can
be used. YOu can also make a .dll call to the Profibus card driver. OPC is
much easier.
"David Wikner" wrote in message
news:b6gk0a$563n0$1@ID-13680.news.dfncis.de...
no
> /david
(9,100 Views)
Use the SyCon OPC server
(8,394 Views)
i use pressure sensor and connect it to ET200 then i connect ET200 with profibus to cif 50 card. i want to plot pressure graph in lab view please help me
best regard
muhammad
(7,327 Views)
hi
i use this hilscher_profibus.llb file.but i have problem.my vi and the fault attached.
please help me
whats is my problem?
and how can add llb file to lab view
i am beginner
best regard
(7,299 Views)
Hi Plinio21,
How is that used in combination with a VI of COMSOFT?
(4,346 Views)
