Labview and pointer arrays
I just started working with Labview and I am facing a bit of a
problem.
I have got a DLL that I need to interface, so I use the Call Library
component.
That DLL needs its input in a pointer array, and returns its answer in
a pointer array.
Layout
The input param. Is a pointer to an array ( two items ) that are
pointers to matrices with data.
prhs --> prhs[0] ---> Struct matrix A
prhs[1] ---> Struct matrix B
The output param has the same layout.
plhs --> plhs[0] ---> Struct matrix result A
plhs[1] ---> Struct matrix result B
plhs[2] ---> Struct matrix result C
It is a Matlab compiled DLL.
My problem is how can I get the data in and out of the matrices.
The param. defined in the call
library component is of type : Double
pointer to value.
Then I pas prhs and hope to receive plhs.
can someone help me.
Kind regards, Enrico Vullings.
(2,954 Views)
hallo enrico,
i find myself in the same trouble, have you ever solved your problem?
thanks and regards, andrea
(2,954 Views)
