Labview and NI MAX Installation issues
I installed NI MAX and then Labview, my goal is to use the NI software to measure temperature with some thermocouples. I was not able to find the "DAQ Assist" command found in the example below. I read on your website that I needed to install Labview THEN NI MAX. So I uninstalled NI MAX and when I try to reinstall it, it looks like it is still installed and won't let me continue after selecting which software.
(1,691 Views)
I assume you installed the NI-DAQmx device drivers as well?
(1,683 Views)
Have you (ever) successfully installed LabVIEW?  You seemed to say that you installed MAX before installing LabVIEW.  If this is true, please try to find a knowledgable student, colleague, anyone to undo what you've done and do a proper LabVIEW installation for you.  LabVIEW installation can be a bit of a challenge, and NI hasn't made it any easier with NIPM ...
(1,652 Views)
