Labview Vi to get size of disk space available
Hello All, Hope everyone is doing good in covid time. I have came across one interesting problem. We want to build a vi which will return us available size of C drive D drive and E drive on any computer.(Naming of drives are given as example).
We have tried searching for labview help but there are no such VIs which can give us disk size available on Windows machine.
Any hard coder here please guide us!
Message 1 of 14
(4,999 Views)
Open ni example finder and search for memory.
You will get a example named resource monitor.vi
It will help you.
CLD Using LabVIEW since 2013
Message 2 of 14
(4,990 Views)
It will help you.
This vi requires an additional NI driver (System Configuration).
There's for sure the possibility to use .NET or other system calls to get this number.
A simpler method is to run the console command dir C:\ (or whatever unit) and parse the output string.
In the example below I show the final part of the output string where the penultimate line contains the required size.
Paolo
Message 3 of 14
(4,978 Views)
wiebe@CARYA  ha scritto:
Ah, it's so simple... I never used this function.
I gave confidence to the OP claim (that there is no solution available) but I should have not.
Actually, if you lack experience also means you don't know where and how search something.
Paolo
Message 5 of 14
(4,965 Views)
Man instead of making fun of me try helping. We do not have full development version of labview accessible to us. We get hardly 1 hr to use labview in our institute. Thanks for your reply anyways. This vi returns size of only 1 disk.
Message 6 of 14
(4,939 Views)
Believe me, I tried to help, but I should have given a check to the Advanced File Functions palette before. My bad.
I can add that everyone here did not know where to search for a few weeks/months after starting to program with LabVIEW.
Paolo
Message 7 of 14
(4,936 Views)
AFAIC, the joke was mostly on himself, not you...
Put the function in a loop and loop over each letter:
Message 8 of 14
(4,920 Views)
Thats look great. Thank you so much for your contribution.
Message 9 of 14
(4,882 Views)
Hey mate! Do you have this VI with you. If yes can you please post it here?
Message 10 of 14
(4,889 Views)
