Labview Versions
I am currently keeping a log of all the installed software and the versions on our computers. I was wondering if someone could help me identify which version of Labview the following software and versions fall under, the list can be seen below:
Thank you very much in advance.
(2,971 Views)
Best bet is to contact NI to verify, but it's sometime around the 2015 SP1 release I think
I still haven't got anything later than that (apart from an NI DMM upgrade I needed to fix a bug) on my PC as I'm waiting for a USB stick of 2017 SP1 and I've got lots of those numbers on my machine.
(that would be Spring 2016)
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
(2,966 Views)
I think it is important to note, that there is no "version of LabVIEW" that goes with that stuff - as there's a release of Labwindows / CVI in the list! and so whatever is on the machine will have been programmed in that!
Looks like CVI 2010 + lots of other later S/W! hmmm.Smiley Sad
Indeed the CVI 2016 support would suggest that CVI 2016 found it's way on there at some point and was uninstalled!
James
(2,963 Views)
