Labview VI to read data from a PS/2 keyboard or mouse
Is there a Labview VI to read data directly from a PS/2 keyboard or mouse? Or alternatively a LabView VI to do the same from a PS/2 device connected to a NI DIO board?
I would like to use the output of an optical mouse encoder as an input to a LabView program. I can do it via the PS/2 port (I am using a USB mouse, so the PS/2 port is empty) or via a NI DIO card.
Any thoughts, hints?
Thank you very much
Costas Pitris
(3,468 Views)
At least since LabVIEW 8.0 there are VI's in the palette to grab data from the mouse and keyboard. They shouldn't care if they are USB or PS/2. This might go back to 7.1 or 7.0. I don't have them installed right now so I can't check.
Look in the "Connectivity>Input Device Control" palette.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(3,450 Views)
Is this a second keyboard/mouse distinct from the one that the PC itself uses?
Mike...
LabVIEW Champion
(3,443 Views)
Yes! Indeed, we are talking about a second mouse keybord and not the one that windows uses as to move the cursor or input text.
Put another way, what I am looking for a is a set of vi's to read and write bytes to a PS/2 device.
Costas
(3,424 Views)
For pre-built functionality within LabVIEW, there are VIs which use DirectX calls to directly read input devices (mouse, keyboard, joystick) on the Connectivity->Input Device Control palette.  Another possible option would be to use a joystick as the input.
Let me know if you have any more questions.
Craig D
Applications Engineer
(3,382 Views)
