Labview USB Connectivity and Davis Vantage PRO console
We are trying to configure Labview to read data through the USB port for a non-NI device (Davis Vantage PRO2 Weather Station)
The USB port is not accessible under the devices and interface session in MAX. Are we missing drivers or any other support software in order to access the USB port?
Thank you.
(3,837 Views)
There are three ways that a USB device will show up in MAX.
1. If the vendor implements a USB->RS232 scheme, then the device will show up as an additional com port. You can then communicate to it just like any other RS232 serial device.
2. If the vendor implements the device as a USBTMC device. This is the USB Test & Measurement Class. Vendors such as Agilent, Tek, etc. use this and their instruments with a USB connection are programmed just like their GPIB instruments.
3. Follow the instructions at http://zone.ni.com/devzone/cda/tut/p/id/4478 and define your own VISA interface to the device. While using the wizard to create a VISA device is not that hard, getting the information on the exact protocol the vendor has used for the messages can be quite difficult to get. If the vendor provides a dll and an api for the dll, that is often much easier to use with LabVIEW's Call Library Function Node. Sometimes instead of a dll, the vendor might provide an ActiveX interface that is dcoumented. This could be controlling an application program that the vendor provides.
(3,828 Views)
Here's a link on Davis's site for the serial communication protocol and a dll for the Vantage Pro2 in case you need them.
Nice station, I have one myself, the Monitor II served me well for a decade, I decided it was time to upgrade!
http://www.davisnet.com/support/weather/software_dllsdk.asp
Have fun!
(3,821 Views)
