Labview + Python
How can I configure the return value of a Python Node in LabVIEW to output two values?
My python code is very simple
def calculate_sum_difference(num1, num2😞
    sum_result = num1 + num2
    difference = num1 - num2
    return sum_result, difference
Message 1 of 11
(3,038 Views)
Your python script returns a tuple:
The LabVIEW code should reflect this by wiring a cluster to represent the python tuple type:
Message 2 of 11
(3,019 Views)
Could you please show me where to find these two blocks?Sly_Nguyen_0-1750318605184.png
Message 3 of 11
(3,007 Views)
It is a cluster of 2 numeric constants
Please read this carefully before proceeding:
https://www.ni.com/en/support/documentation/supplemental/08/labview-arrays-and-clusters-explained.ht...
Message 4 of 11
(3,002 Views)
Thank you for your help, I have completed it
Message 5 of 11
(2,980 Views)
I added code to be able to log every time it runs. When using LabVIEW, an error occurs; can you please take a look to help me?
Message 6 of 11
(2,737 Views)
Well, your python function returns a list... Which I don't think you want, since error_code is a number and result a string (shouldn't this be a boolean?)
Remove the [ ] from the return line. Then make sure that the order of you LabVIEW cluster is the same as your python tuple.
Message 7 of 11
(2,730 Views)
Looks like your python code returns number, string and the LabVIEW code expects string, number. Order needs to match.
Message 8 of 11
(2,726 Views)
Thanks for the help, I got it running. But only when running python log appears. What do I need to install for labview to be able to have log when changing reference values
Message 9 of 11
(2,712 Views)
The file is probably being created just not where you expect. Because you didn't specify a full path python is treating "log.txt" as a path relative to the working directory. Try an absolute path like "c:/log.txt" assuming Windows. Don't forget to escape the /, put "c://log.txt"
No idea where the working directory is in a python node...
Message 10 of 11
(2,684 Views)
