Labview Program for acquiring two values after a given period of time
Hi
I am a final year student working on a project.
I want to make a vi which will measure two readings of the data such that the first reading is the initial reading and the second reading is after a certain period of time.
Basically I want  to measure fuel flow using a strain gauge. The concept is that a small fuel tank is fitted on the strain gauge. At first the fuel tank will be full (note: this will be the first reading) and after 60 Seconds there will be a decrease in weight of the fuel tank due to fuel consumption (note: this will be the second reading).
I want to subtract the final reading from the initial reading and divide the answer by 60.
Please tell me how to do this.
Thank you.
The hardware I am using is chassis cdaq9172 and Ni 9129.
Message 1 of 8
(3,396 Views)
Let's start from the beginning.  Do you know how to take a measurement?  I see you are using a strain gauge, but how are you reading it?  DAQ?  DMM?
GCentral
Message 2 of 8
(3,392 Views)
well i am using a four wire strain gauge and interfacing it using ni9219 in cdaq 9178 chassis. I am using a DAQ.
Thank you very much for your reply. I am a begineer.
Message 3 of 8
(3,384 Views)
I would setup the DAQmx task to sample every 100ms for 1 minute (600 samples).  Tell the task to run, wait the 60 seconds, read the data, do your math on the 0 and 599 indecies.
GCentral
Message 4 of 8
(3,380 Views)
Will you please tell me how to do so?
Message 5 of 8
(3,376 Views)
GCentral
Message 6 of 8
(3,368 Views)
Thank you  very much. I really appreciate your help.
Thanks a a lot.
Message 7 of 8
(3,351 Views)
Hello
I have tried to make this in Labview 2009 but I am finding it hard to make the VI as I am not professional in using Labview 2009.
CAn you please explain further so that I can make this VI in labview 2009.
Message 8 of 8
(3,317 Views)
