Labview OOPs
I want to use LabVIEW Object-Oriented Programming (LVOOP) to develop an  application  by using  NI DAQ Cards like analog inputs cards, analoga outputs cards etc... Can I  dedevelop code easily by using LV OOPs concepts? Are there any restrictions?
NI CLDlabview-programming-fundamentalslabview-environment
(3,428 Views)
Hi Veerababu,
                    If your condition suits the below listings you can go for LVOOP
Who should use LabVIEW object-oriented programming?
  • VIs to be maintained for a long time
  • Large application
  • Multiple developers working on same VIs
Who should not use LabVIEW object-oriented programming?
  • Express users
  • For the quick, single VI to take a measurement, LabVIEW classes are overkill
To learn about LVOOPs see to the link  https://www.ni.com/en/support/documentation/supplemental/06/labview-object-oriented-programming-faq....
Kudos Welcome 😄
Certified LabVIEW Developer
Best LabVIEW Programmer @NIDAYS 2015
(3,411 Views)
