Labview: Memory is full
I have this subvi. Everytime I want to save work on it.
When I re-open the vi. It always said "Labview: Memory is full"
can someone please take a look at this and see what's wrong with it?
Thank you in advance
Krispiekream
Message 1 of 9
(4,981 Views)
can't open it right now, but do you have any large arrays? If you are dealing with an image you may, and that could be the problem.
Message 2 of 9
(4,978 Views)
i dont think i have any large arrays.
i tried disposing the image after i finished with it, but that didnt worked.
Krispiekream
Message 3 of 9
(4,972 Views)
I just took a shot in the dark. Without opening it I can't help much, sorry.
Message 4 of 9
(4,969 Views)
I had no problems opening (except for the fact I don't have IMAQ).  The file isn't that large and the memory usage once opened isn't that large.  I opened it in LV2009SP1.
Try opening the attachment after I saved it back to LV8.5 again.
Message 5 of 9
(4,940 Views)
i got this trying to open your program
this program was saved in labview 8.5
Krispiekream
Message 6 of 9
(4,929 Views)
could it be that its because VISION ASSISTANT 2009 was used and it create for labview 8.5 and it doesn't allow me to save and work on labview 8.5?
Krispiekream
Message 7 of 9
(4,920 Views)
Accepted by krispiekream
Very strange.  I got that same message to when trying to download that VI.  I didn't actually try reopen the VI after the save for previous.
I wouldn't think vision assistant would be a problem.  I don't have that and I was able to open up your posted VI.
But I tried saving for 8.5 and 8.6.  I tried removing the subVI's and disconnecting typedefs.  All of those are still causing error 3.
I would guess something is corrupted in the VI.
Message 8 of 9
(4,914 Views)
i can save work and do things in labview 2009 without a problem.
i only have problems when trying to run in labview 8.5
Krispiekream
Message 9 of 9
(4,912 Views)
