Labview Measurement & Automation Explorer very slow
Hello all,
 The following is my system configuration and LAbView version:
  • [ LabView professional Development System - Version 11.0 - 32-bit ]
  • OPERATING SYSTEM - [ MS windows 7 Home Premium 64-bit SP-1 ]
  • CPU - [Intel Core i7-2600 CPU @ 3.40Ghz ]
  • MEMORY - [ 16.0 GB RAM ]
  • GPU - [ NVIDIA GeForce GT 530 ]
  • NI PXI-7951R & NI 5761
Everything works absolutely fine until yesterday. All of sudden, everything related to LabView is very slow. Sending commands to run the stepper motor and even checking out Measurement & Automation Explorer. There havent been any major changes in National Instruments software removal or updates. Everything is intact. My antivirus is AVG ( which is a recent change after I removed mcaffee, but I dont think that might be the reason ).
any kind of advise is appreciated.
Thanks.
Abhilash S Nair
Research Assistant @ Photonic Devices and Systems lab
LabView Gear:
1. NI PXI-7951R & NI 5761
2. The Imaging Source USB 3.0 monochrome camera with trigger : DMK 23UM021
(4,060 Views)
Okay, so what were the "minor" changes?
Bill
CLD
(Mid-Level minion.)
(4,049 Views)
Installed COMODO firewall. Thats it.
Let me remove that and try again
Abhilash S Nair
LabView Gear:
(4,042 Views)
Hopefully this link will help you configure your firewall for use with LabVIEW (and other NI products)...
Good luck!  🙂
Bill
CLD
(Mid-Level minion.)
(4,031 Views)
Accepted by topic author abikutn
Adding or changing your antivirus/firewall can actually have a major effect on LabVIEW and related products, because they can potentially block your network connections. MAX scans your network for remote devices.
I also had an issue some time ago where my firewall blocked access to shared variables. Following these instructions helped me: https://www.ni.com/docs/en-US/bundle/labview/page/changing-the-default-ports-for-tcp-based-ni-psp-ni... (I don't think this affects MAX, but I'm mentioning this in case you run into a similar problem)
Certified LabVIEW Developer
(4,015 Views)
