Labview Maximum Controller Handles
I am looking into using labview to sample 10-15 variables from 10-15 different Galil based Ethernet controllers (DMC22xx, DMC40x0, and some RIO-47xxx's). I was wondering what the maximum number of simultaneous connections over an Ethernet network would be?
I would like to be able to record and view these values at about a rate of one set of samples per machine per second.
(2,461 Views)
Accepted by topic author LHeath
The limitation should be based on the number of available ports and addresses on the Transport Layer. This is a TCP limitation (65535).
(2,453 Views)
