Labview Linux X Forwarding Flashing
Hello. I am running Labview 2012 for linux on a remote box. I am using putty in combination with XMing for X11 forwarding. However, sometimes Labview starts flashing white and commands no longer work. I feel like this is an issue with the x forwarding and could be easily solved by changing a setting. I was wondering if anyone has any experience or ideas to help solve this problem. Thanks.
(3,833 Views)
Hi Keenan,
What other programs are you running?  Is this reproducible with another program or just LabVIEW?
James K.
(3,806 Views)
I have yet to see it in any other applications that I have x forwarded. So I would hazard to guess that it is just labview. Furthermore it seems to only happen when the context help window is open.
(3,801 Views)
I see the same problem when I use an X11 window open on a remote machine. This occurred on 2011 version but I do not believe it occurred on 2010 version. It seems to me that Labview is trying to update the context windows too often, thus you have the flashing issue.
(3,797 Views)
It sounds like it might be a rendering issue.  Have you tried investigating this from the Xming side?
James K.
(3,780 Views)
I was using cgywin for my access. There is a possibility that it could be a gnome or kde problem. It seems to have gone away for now. I am running on OpenSUSE 12.2 AMD64 with the latest patches.
Because of the flashing, I tend to use a minimal amount of display to avoid the flashing.
(3,773 Views)
I think we have some bit rot in the windows system. I tried it las night at the end of the day and got a lot of flashing just opening the context window. This morning I did the same thing and none of the flashing occur. I suggest the following: 1. log out and login or 2. reboot the machine. Make sure you have plenty of ram.
(3,754 Views)
