Labview - LIN Goepel 3072 - Example code
Is there example code for managing with Labview the LIN communications with the Goepel card PXI3072?
I've bought the card to Goepel (it's indicated on the NI web) but I've only one sample and the manual guide, I'm searching on the forums but I don't find additional support.
If someone can help me ...
(3,738 Views)
Hi Ihb,
You should have found some examples along with the Drivers provided in the CD which comes along with the card. If not, you can contact Goepel and they can provide them.
Also, using the card is not that difficult. As long as your header command construction is ok, you should not have problems since this is the basic foundation for sending commands to the card.Smiley Happy
Ashm01
(3,716 Views)
