Labview Job, Rochester N.Y.
If you live in the Rochester N.Y. area, please read:
Summary:
Trison operates fuel cell test stands which perform automated testing
of components by controlling and monitoring pressures, flows,
temperatures, and current. The project engineering group customizes
these stands in response to the ever-changing needs of researchers. We
also design equipment for specialized on-site testing. Most of the
equipment is PC controlled using LabView code in a Windows environment.
The Senior Labview Engineer develops and modifies control software for
these test stands. Attention to detail is required in a fast-paced
multitasking research environment.
Position Responsibilities:
- Develop control concepts to meet testing
requirements
- Write and debug control software
- Work with electrical and mechanical engineers to
integrate systems
- Verify system operation and document
installation
- Communicate project progress to customers and
management
- Assist Maintenance to debug and repair equipment
- Share expertise with software team in weekly
code reviews
- Suggest improvements to existing equipment and
processes
Position Requirements:
- 4 year Electrical or Mechanical Engineering
degree
- Extensive experience writing LabView
applications for machine control
- National Instrument data acquisition hardware
experience: PXI, SCXI, Fieldpoint, DAQ
- Access, VBA, AutoCad experience desired
Salary: $50-70K based on experience.
"Trison Business Solutions, Inc. supports and complies with Equal
Employment Opportunity and Affirmative Action act in all employment
practices. Accordingly, all applicants and employees will be treated
fairly and equally without regards to color, religious creed, national
origin, or sex."
(3,366 Views)
I have around 6 years of experience in labview. I am looking for a job now.
Can you please give me your mail ID?
seu12
(2,959 Views)
You probably did not notice that you are responding to a job opening from 2006. My wild guess is that a lot of things have changed since then. 😄
I would recommend to look in this forum instead for more opportunities.
(2,951 Views)
Not the first time ignoring the date.
(2,943 Views)
