Labview Interview questions..?
Hiiii alll,
Does any one tell me what type of interview questions i may expect in Labview with 2 years of exp. (i"am going to attend an interview in an QUEST.)
pllzzz plzz do needfull frnds...
thank you all.
Message 1 of 13
(9,188 Views)
I would expect questions similar to what you would see for CLA certification plus hardware. Depending on what the company is using, it might be DAQ, FPGA, GPIB, etc.
Message 2 of 13
(9,183 Views)
Oops, typo there. Meant to type CLD.
Message 3 of 13
(9,174 Views)
Wt type questions I may expect related to DAC
Message 4 of 13
(9,116 Views)
"What is your forum username?"
*finds this thread*
You can probably expect to talk about some of your previous LabVIEW projects, what architectures/communication methods you've used, what communications protocols you've used etc.
I would also expect some sort of practical test - asking you to solve a simple programming problem or interface with a device/instrument that the company uses. It's also quite common to be shown a piece of code to 'spot the mistake'/'what does this code do' or be shown some more complex code to review the code with the interviewer to discuss different/better ways of doing it.
(blog)
Message 5 of 13
(9,133 Views)
For a DAQ question, I would expect you to explain or code a basic analog acquisition - setting the terminal configuration, sample rate, number of samples, number off channels. Using MAX, a project, or a VI for these settings. If it was me doing the interview, the use of the DAQ Assistant would not be acceptable for anyone other than a brand new user.
Message 6 of 13
(9,101 Views)
I would also expect that someone with two years of experience would be able to spell LabVIEW correctly. When I was hiring, resumes with it misspelled went right into the trash can.
Message 7 of 13
(9,095 Views)
Accepted by Muniraju
@muniraj wrote:
Hiiii alll,
thank you all.
I'l retell a story about one of my interview's.
FIRST- I can spell "LabVIEW" - as Dennis mentioned, If you cannot spell it, the resume goes in the "circular file"  (Trash- can)
I expect to be asked about my knowledge of LabVIEW when inteviewing.  I "Do LabVIEW" for a living! Practical exams are not uncommon.  Can You whip out a vi meeting some specifications? Knowledge tests are common too- I more often correct the answer keys rather than get a answer wrong.
So, I once was challenged with EACH of a written exam and a practical exam.... the code fit on a bussiness card and I posted a u-Nugget about "Ignore errors inside property nodes" that week.  I Also ate "Tommato Basil" soup for lunch while wearing a white dress shirt that day.
SO, Are you any good?---- I might need an intern
"Should be" isn't "Is" -Jay
Message 8 of 13
(9,065 Views)
Is it okay to just open up an example for these practical tests?
I have to set up a lot of simple proof of concepts or tests for people and it's usually just a modified example, especially for multifunction DAQ or CAN.
Message 9 of 13
(9,020 Views)
Depends on the job. For an intern or entry level where no/little experience is required, that might be enough. I usually expect some actual programming to be done.
Message 10 of 13
(9,006 Views)
