Labview - Graph
May I have another question to this topic?
I need to connect a 100 ohm resistor in series with the diode.
How can I do this in LabView? I browsed the Functions drop-down menu and I haven't found a resistor.
The resistor is necessary to set the bias point of the diode.
Thank you very much in advance!
Message 11 of 15
(1,325 Views)
I have another question - what kind of LabView block is the one marked by the red circle?
Thank you very much!
Message 12 of 15
(1,310 Views)
LabVIEW is a programming language, not a circuit simulator (NI makes Multisim and Ultiboard for that).
You can model electronic circuits with math, but you can't simulate actual components.
Message 13 of 15
(1,306 Views)
That VI is Get Waveform Components from the Waveform palette.  It separates a waveform into its components:  Start TIme, Delta T and an array of Y points.
Altenbach used it to extract the Y array so he could perform math operations on the datapoints.
Message 14 of 15
(1,303 Views)
Thank you all!
Message 15 of 15
(1,285 Views)
