Labview FPGA code modifications
I'm working on 802.11 application framework i tried to modify the FPGA code.
Do i need to really compile the entire code after modifications?? or just save  the VI to observe the effects of modification.
(3,409 Views)
Accepted by topic author varugantigopal42@gmail.com
Yes, LabVIEW code needs to be compiled using the FPGA toolkit after making any modifications. I think the only exception to this is when you run in simulated mode on your PC.
(blog)
(3,366 Views)
