Labview FPGA code modifications
I'm working on 802.11 application framework i tried to modify the FPGA code.
Do i need to really compile the entire code after modifications?? or just save  the VI to observe the effects of modification.
(3,429 Views)
Yes, LabVIEW code needs to be compiled using the FPGA toolkit after making any modifications. I think the only exception to this is when you run in simulated mode on your PC.
(blog)
(3,386 Views)
