Labview FPGA Error - Urgent Please
I have been experiencing this problem for a while and it is driving me crazy. When I try to program my Spartan 3E fpga board, I get a message, it compiles successfully. Then I get an error stating that
"Labview called another software component and that componen returned ther following error:
Error Code = -2147483648
Error -2147473648 occurred at nilvcseInitChain.vi
This error is undefined. No one has provided a description for this code or you might have wired a number that is not an error code to the error code input."
Please Help!!!
Message 1 of 14
(5,802 Views)
Accepted by eceone
1.  What version of LV are you running, 8.5 or 8.6?  What operating system are you using?  XP, Vista (32/64-bit?)
2.  Go to Device Manager (right-click My Computer/Hardware tab).  Do you see a category called "Programming Cables" and is the Xilinx board listed under it?
reid
Message 2 of 14
(5,794 Views)
Hey,
Is this just comeing up with your VI or with any VI you compile?
This might be a problem with the board itself. Are you able to test another board or FPGA hardware?
Christian
Message 3 of 14
(5,792 Views)
I'm running labview 8.5. I installed the module on my desktop months ago and it worked perfectly. Then, I installed the module on my laptop and I can't seem to get it to work recently.
I really hope it's not my board because i can't afford to get a new one anytime soon.  I use the board for other verilog programming and it works fine. I even successfully wrote  a xilinx verilog module on my board last week.
I don't know what to do. I need this to work for my senior project.
Thanks for your help.
Message 4 of 14
(5,776 Views)
I have tried various VIs and even some examples provided by NI and still no luck.
Message 5 of 14
(5,774 Views)
Did you check Device Manager and make sure the device shows up under Programming Cables?
Message 6 of 14
(5,772 Views)
I haven't done that yet. I'd do it and let you know if it works.
Thank you for your help.
Message 7 of 14
(5,770 Views)
Message 8 of 14
(5,730 Views)
Thanks, it works fine. Apparently the xilinx usb cable was not properly configured.
Message 9 of 14
(5,727 Views)
I am getting the same previously defined error. The xilinx cable is configured properly. the fpga works fine. I don't know what to do. I am using Labview 8.5 with Windows XP. Please help.
I am frustrated already.
thanks
Message 10 of 14
(5,591 Views)
