Labview Error - Can You help?
Possible reason(s):
LabVIEW: Open VI Reference will no longer match VIs in memory by file
name.
A VIs full name now includes any owning libraries so a filename is no
longer sufficient.
You can use strip path to wire the filename as a string, but this will
not work for VIs in libraries.
VI Path: C:\Program Files\National Instruments
\LabVIEW 8.0\examples\Sound and Vibration\Utility\Cosmetic\
SVXMPL_Third Octave Analysis for Multiprocessor (Simulated).vi
I get the above error when I run a LabView example on 1/3rd octave
analysis. Any ideas?
N.
(2,690 Views)
naebad,
Are you just running the example program?  If this is the case, it looks like it could have been modified.  I would uninstall and reinstall the sound and vibration toolkit.  After installing the toolkit again, the example will be back and you should be able to run the examples.  I think that the example doesn't work because it wasmodified.  Let me know if this is not the case.
I hope this helps.
Steven T.
(2,663 Views)
