Detecting and Killing a process in Windows
I have looked at the utilities posted in Winevent.llb (from lvwinutil.zip in a previous discussion thread from way back in LabView 4!)
The TaskList function works fine, but there is a missing .vi "PostMessage Master.vi" in "Quit Application.vi"
Does anyone know where this is hiding?
Alternatively, is there another (better?) way of achieving this?
I need to detect the presence of a task and terminate it if found........
If the method will work on Windows 2000 AND XP, so much the better.
Ta....
(3,346 Views)
I have lvwutil library (though I don't use it), so I can verify that VI is in the WINUTIL.llb file. You may want to download the lvwutil library again from NI.
(3,326 Views)
Thanks - found it.
I am also trying SystemExec.vi and calling the taskkill.exe directly -seems I can make it work both ways.
Now comes the trick - make it robust! - Cheers........
(3,318 Views)
I don't know how much more (or less) robust this would be, but you could also utilize the call library function node.  With Kernel32.dll, using the "TerminateProcess" function.
I don't know the 'find all processes' function offhand but I know it's in there.
Just an idea!
(3,312 Views)
Surprise, surprise, I'd recommend using .NET - much easier to work with in LabVIEW than Win32 - as long as you have LabVIEW 7.1 or later.
If you don't have it already, install .NET 2.0 or .NET 3.0 (just released).
Go to examples\comm\dotnet\SimpleTaskMonitor.llb and take a look. It's a large example, so don't get overwhelmed - but you should be able to pull out the basics on how to get the list of running processes via .NET. Then the Process object has a Kill() method you can use.
(3,271 Views)
