Labview EXE calling external EXE
I am having trouble with embedding exe (which is written in C) while building Labview EXE. I have a VI that calls external EXE using System Exec.vi function. When I build the application from Labview, it neither includes external EXE nor can access it even if I place it to the same location where Labview EXE is.  How can Labview EXE call an external EXE?
(3,443 Views)
In your LabVIEW VI  is the given path for the executable in System Exec. vi is absolute or relative ?
Pierre R...
Certified LabVIEW Developer
(3,436 Views)
I am using absolute path which is created dynamically by using VI Path.vi.
(3,420 Views)
Hi magnetica,
 Can you post your code?
Thanks and regards,
srikrishnaNF
Srikrishna
(3,418 Views)
