timing a task without waiting
Dear Labview Board,
I have a section of code in my VI that writes boolean values to digital output (bottom of the block diagram).   Right now I do this with the wait function inside a case structure.   This works, but has a side effect I would like to eliminate.   Because this code is within the context of a while loop, the wait function holds execution of everything until complete.   I want timing, but I need the rest of my looped logic to continually run.   Please see the attached VI.
Does anyone have any suggestions?
Zach
PS - I can't open anything beyond v8.6
(2,698 Views)
Accepted by topic author super-neuron
See attached file.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(2,658 Views)
Thanks Gaurav K!
Its elegant and simple!
(2,632 Views)
