Labview, Change the phase between 2 signals dynamically
I'm working on a big VI , and for testing my VI I have some controls.  A part of my VI is to generate 2 sine signals with the same amplitude and frequency and a phase difference between thoses 2 signals.
My example is quite simple but very similar the one I use :
- I can change frequency and amplitude while the VI is running.
- I can't change the phase.
Anyone have an idea ?
thank in advance 😉
Message 1 of 8
(6,051 Views)
HI,
I looked in help and there is written: "Phase (deg)—Initial phase in degrees of the waveform. The default is 0. "
So, I think that you are able to set phase only before VI's start.
Simyfren
Message 2 of 8
(6,035 Views)
Thank you for your rapidity, I had only look with the CTRL+H view  ..
Do you have an idea for increase this value during the run ?
I have tried sinewave generator but it work like the "simulate signal" ..
Message 3 of 8
(6,027 Views)
Try to use block "Sine".
Here is small example:
Hope this helps!
Simyfren
Message 4 of 8
(6,019 Views)
Hi Simyfren,
I have try your solution but it doesn't give anything usable for me..
I have also tested a lot of stuff but nothing comes good.
If anyone have an idea, he's welcome 🙂
Max
Message 5 of 8
(5,931 Views)
Max,
When you say nothing useful, do you mean the VI did not run? Or, do you mean it runs but does not behave the way you want it to?
Dan
Message 6 of 8
(5,919 Views)
Hi Danl_B,
My VI run, but I haven't a sine at my output. if I use a graph chart I can see a sine (not really good in résolution, it's more like a triangle) .
And if I set this signal for my DAQ analog Output and after that Acquiring with an other DAQ, it doesn't show me a sine but a square with strange change of amplitude.
I hope you can understand what I mean, my english is poor..
Max
Message 7 of 8
(5,898 Views)
Accepted by topic author MaxLamb
I have find the solution :
I have set the input "reset signal" of Simulate_signal.vi with a constant TRUE. And with that it works fine !
Sorry for being a noob 😉
Hope this will help someone else.
Message 8 of 8
(5,891 Views)
