Labview - C#
I just wanted to know whether calling a LabView DLL from C# code is possible or not.  I am trying to pass binary data from a C# program to LabView (in order for the latter to process and plot the data).
Thank you.
(4,769 Views)
It is possible, but you must remember that the DLL is unmanaged with a C interface. This means you'll need to define P/Inovke signatures for DLL methods. If you go to www.pinvoke.net, you'll find tons of examples on mapping P/Inovkes for Win32. A great place to get ideas for your own.
(4,743 Views)
Brian, thank you for replying.
I went to pinvoke.net and (unfortunately) got lost. Yes, I am a newbie Robot Sad.
I guess what I want to know is the difference between using Visual C++ and C# when it comes to calling a labview DLL.
My knowledge about using Visual C++ to call a labview DLL could be summarized using the following example:
Calling a LabVIEW-built DLL In C to Acquire, Analyze, and Present Data
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=D6463414BBFF1646E034080020E74861&p_...
This  example is very simple (you don't pass or get data to the DLL ). However, I am assuming that if I need to call a labview dll in Visual C++, I should include the same *.h files (basically, I would have the same setup). Now, I don't think that I can use these *.h files in C# and expect them to work (though I have not tried).
What do you think?
(4,731 Views)
That is correct, you can NOT include .h files into C#. The languages (C# and C++) are much more different than the names imply. But, creating a P/Invoke isn't very hard, as long as you stay with simple data types. An example for calling a LV DLL with no parameters would be
[DllImport("mylabview.dll")]
static extern void MyLabVIEWFunction();
class MyClass
   public static void Main()
That's it.
(4,698 Views)
Ok. Thank you Brian Robot Happy I will give this a try and we will see what happens.
(4,693 Views)
