キャンセル
次の結果を表示
次の代わりに検索
もしかして:
Labview 8.5 error on save: "Cannot load help information of [filename]."
I will give this a shot the next time it happens.
Chris
0 件の賞賛
メッセージ11/23
3,387件の閲覧回数
Thank you, Marti! That worked well for me, and saved me a few hours of work.
Brad
0 件の賞賛
メッセージ12/23
3,312件の閲覧回数
Thanks Marti!
I had the same issue in Labview 2010, and copying the file from the recovered files directory fixed it.
Whew.  Must remember to save more often.
Ro ma wa ichi ni chi ni shi te na ra zu
0 件の賞賛
メッセージ13/23
3,132件の閲覧回数
But what are the causes of this.  I have a VI that is repeatably doing it.  I have tried copying and pasting the block diagram and that fixes the problem for a while but it always comes back!!スマイリー 悲しい
0 件の賞賛
メッセージ14/23
3,062件の閲覧回数
Same problem. Lost 2 hours of work after opening the crashed VI. Why don't they find a proper solution???
0 件の賞賛
メッセージ15/23
3,044件の閲覧回数
Hey
Even i faced the same problem with 2010 version , where after an internal crash i could neither save nor copy (select all) to another file.But then in my case i felt it was an express VI that caused the problem . So i just removed nly those three express VI's present in the whole program,then gav (select all-copy -newfile)everything went perfect.This actually saved me the effort of coding it all again.I lator pasted those VI's separately into the new file.Hope this might be useful to someone
Namitha
メッセージ16/23
3,024件の閲覧回数
On LabVIEW 2011, I tried removing the express VIs as suggested. It allowed me to save, without having to copy-paste to a new file. It points towards an issue with the recovery of express VIs.In my case, I were using a DAQ Assistant express VI within a loop.
0 件の賞賛
メッセージ17/23
2,882件の閲覧回数
Yes!!!!
I had one express vi in my code (time delay - very uncommon, I'm sure not many are using it).  I deleted it from the recovered block diagram and WHAMMO I can save again!  Thanks for the tip!
BTW:
LV2012
Win7(x64) Build 7601 service pack 1
0 件の賞賛
メッセージ18/23
2,639件の閲覧回数
I had the same error, luckily I tried to save straight after adding a display message to user express VI, I just removed it and the error went away.
0 件の賞賛
メッセージ19/23
2,504件の閲覧回数
For information:
I just encountered this in LV2011.
I'd restored a paused Virtual environment, and the path to a few VIs was actually through a shared pipe to the host drive. Upon restoring the virtualised OS the shared resource wasn't available, and hence to LabVIEW it had appeared that suddenly these VIs were missing. Their entire file path was unavailable.
Upon restoring the path to their location they recovered without a problem.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
0 件の賞賛
メッセージ20/23
2,456件の閲覧回数
