Labview (8.5) Crash by adding item to typedef
Hi Folks -
I have a VI that is fairly large and complicated.  A strict typedef is used to add cases in a producer-consumer event-driven state machine.  I have 87 items in the strict typedef now.  When I go to add the 88th item, no matter what I name it, a broken run arrow appears on the toolbar and when I click on that it, no errors show up in the error window, but a few seconds later, LabVIEW crashes.  I have tried starting over several times with backed up versions of the code to make sure I don't have a corrupted VI but always get the same result.  When I remove the 88th item, the run arrow is no longer broken and I am back to the VI working fine.  I have also rebooted the computer but get the same results.  I wonder if I am running into some sort of memory issue.
This VI is not something I can simplify or post.  I would have to make an LLB or ZIP out of it and send to an engineer to look at.  I wanted to know if anyone else has run into something like this before - and can maybe point me to something not obvious that I need to look at.
Sincerely,
Don
(2,929 Views)
Try using the old style "Flatten to string" to get the type descriptor for that cluster. Check the size of the type descriptor to see how large it is.
Ben
(2,922 Views)
I should have said I am using a strict typedef enum.  I am attaching it here.
Don
(2,914 Views)
No crash when adding item number 88 using LV 2009 SP1.
Ben
(2,909 Views)
Right, but it is not being added within the context of my application.  I have 64-LabVIEW 2009 installed on another computer w/ 64-bit Win7 with my application partially working right now.  I don't have a 32-bit LabVIEW 2009 (w/ ASP + Vision) installation right now.
I do appreciate your trying.
Don
(2,907 Views)
I found the problem.  It is an odd-ball type of issue that will be hard to explain here.  Basically, I had created a reference to the typedef enum control and it has to be updated when I added the new item.  I don't know why I did not get an error.  There was a broken wire from the reference on the block diagram after updating, but it was hidden from the default view that I was looking at.  Anyhow, the problem, which could have been major, is fixed.
Don
(2,902 Views)
