03-19-2008 11:51 AM
03-19-2008 12:06 PM
Hi Tom Y,
A potential source of the problem may be the service pack version of Windows XP. This customer had tried repairing, reinstalling, MSI Blast-ing, and deleting the registry files, and LabVIEW was still crashing when he tried to open anything project-related. In the system event viewer, there were two errors that showed up: 1) "NI Configuration Manager terminated unexpectedly", and 2) "nidevldu terminated unexpectedly" (screenshots attached below)
The solution in this case was having the customer upgrade from SP1 to SP2, and that fixed his problem. Apparently, the service pack version affected the NI Configuration Manager and the nidevldu processes.
Let me know if you resolve your problem.
03-19-2008 12:53 PM
03-20-2008 02:53 AM
You can try the following as well:
- Fully un-install 'MXS' - by running installer located on LV8 CD -> Bin/Products/MXS. (If it says 'higher version is installed' try DSC 8.0 CD version instead, appears to be newer build).
- Delete the following files:
..\National Instruments\MAX\Data\*.* (All Files)
..\National Instruments\MAX\Data Fragments\niIMAQDD.mxf
..\National Instruments\MAX\nimax.ini
- Repair MAX via Control Panel
- Re-install MXS using same installer as above.
- Reboot your machine. Services should start up correctly and the LV8 Project should be running again.
03-20-2008 08:22 AM
