Labview 6
bonjour,
Où puis je télécharger la version demo de Labview 6.1 ??
je possède Labview 2009 mais je dois faire une appli sur Windows 98 .
Mke
Message 1 of 11
(6,396 Views)
Translation
hello,
Where can I download the demo version of Labview 6.1??
I have Labview 2009 but I must make an application on Windows 98.
Mke
Message 2 of 11
(6,374 Views)
Veuillez entrer en contact avec votre bureau local de Ni. Ils peuvent te fournir une version de LabVIEW 6.x.
Translation:
  Please contact your local NI Office. They can provide you with an 6.x version.
Christian
Message 3 of 11
(6,370 Views)
Labview 7.0 should also work fine with 98 .
Message 4 of 11
(6,367 Views)
Message 5 of 11
(6,366 Views)
merci.
Thanks .
Mike
Message 6 of 11
(6,328 Views)
Have an old LV app requiring labview 6 runtime engine.  Now trying to run it on MS Vista 32 bit.  Is there any libraries upgrade migration support without having to change the original
Message 7 of 11
(5,917 Views)
You could try to install the LV 6 runtime on your Vista computer.  You might get lucky and your .exe will work.  But there is no support for Vista, so if you're not lucky enough, you'll have to get a newer version of LabVIEW, upconvert your VI's and rebuild the application.
Message 8 of 11
(5,908 Views)
Hey gilher,
As stated in the following document, you have very little luck running your application on Vista with LV6 RunTime Engine :
- https://www.ni.com/en/support/documentation/compatibility/17/labview-and-microsoft-windows-compatibi...
The best you can do if it fails is to upgrade your code in LV8.2.1 or later, and rebuild, just like Ravens said. If there are not too many VIs, you can ask to upconvert them here.
Eric M. - Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer - Certified LabWindows™/CVI Developer
Neosoft Technologies inc.
Message 9 of 11
(5,894 Views)
Well I would try that , but I no longer have the disks, the old pc it was on is now long gone (buried/landfill) and I can't seem to find version 6 on the NI support page....so SOL I guess.  I saw the matrix reference by Eric.M.  I will try the upconvert forum.
Message 10 of 11
(5,880 Views)
