Labview 2021: SSH function - Not interactive
There is a new function called "OpenSSH Exec" available in LabVIEW 2021. On calling this function and sending Username, Password, IP and Linux command, i am getting the response. But the challenge here is its not interactive - My Requirement is - when i send a Linux command, i need wait for parameter and then enter a value and then wait for 2nd parameter, again enter value and so on till all parameters are feeded with values. This works perfectly well when i try with command line ssh. But when i send same Linux command on above LabVIEW function, it responds with all parameters in 1 shot without waiting for my input value. Image shown below for reference. Any one has worked on ssh function in LabVIEW and have any suggestions to handle this? I suspect this function is sending return key internally till some End of text/response is received.
Message 1 of 11
(5,500 Views)
NI is supposedly working on a session-based SSH (see the current LabVIEW Roadmap).  What I do currently is use a .NET library (SSH.NET) and I built a class wrapper around this library.
Message 2 of 11
(5,479 Views)
Another option is to use the Encription Compendium library from https://lvs-tools.co.uk/software/encryption-compendium-labview-library/
Not free but it beats trying to cook your own LabVIEW library if you just want to use something rather than DYO (develop your own).
Rolf Kalbermatter  My Blog
Message 3 of 11
(5,470 Views)
Hey Girish
Did you solve this? I am having the exact same problem you posted
Please let me know
Ana
Message 4 of 11
(4,861 Views)
Hey arohr,
From NI Labview, it's not possible to have interactive SSH session. Every time we poll on SSH in labview, it creates a new instance. So, i had to use Python method and call it from Teststand wherever SSH session was needed.
Girish
Message 5 of 11
(4,829 Views)
ok, thanks
I ended up using third-party ALAB SSH toolkit
Ana
Message 6 of 11
(4,820 Views)
How did you go about using the python method to call an SSH session?
Message 7 of 11
(4,721 Views)
I have used Paramiko library (available online). Its pretty simple to use.
Message 8 of 11
(4,699 Views)
Do you have to call it from testStand or would the library load directly if I use the native python module within Labview?
Message 9 of 11
(4,677 Views)
I've used both the LabSSH and Field R&D Services which can both support a session.  However the LabSSH ends up crashing LabVIEW if your target happens to disappear un expectedly.   I would recommend you use: Field R&D Services.   I would get the toolkits from JKI.
The new native SSH building into LabVIEW as of 2021 doesn't support a session, but is easy to use for quick commands and responses.
Message 10 of 11
(188 Views)
